Engine oil inside the Signal Generator Cover ?
Started by rollerfish01, Monday, 11 September 2017, 01:58 AM
rollerfish01
Hi all, today I opened the Signal Generator Cover (Crankshaft Position Sensor) to have a look and found oil smudge inside...
Then I ran the engine (with the cover opened) and there was engine oil spraying out, is that a normal thing ?  :rolleyes:
Not sure about normal, but I often found some oil in there in mine, so nowt to worry about
i don't think it should be full of oil but oil definitely get in there and thats why the cover has a gasket.  :cheers:
I have also some oil inside my signal generator cover. I think its normal.
rollerfish01
Thank you for all the replies  :salute: :salute: !
So I don't need to order for more spare parts. :clapping:
only a gasket if was damaged when you removed the cover and make sure the sealing washer is on the correct fixing bolt on the casing
http://gsx1400owners.org/forum_test/index.php?topic=149.0
check here for sealing washer locations on outer casings
rollerfish01
Quote from: seth on Monday, 11 September  2017, 11:07 PM
Thanks for the reminding !
I think I had put the washer at the wrong bolt... going to fix it tomorrow.  :cheers:
