Ignition Advancer - Standard or 3rd Party?
Started by gsxbarmy, Sunday, 27 June 2021, 07:19 PM
There have been some queries by forum members following purchasing a GSX1400 as to whether or not they have the standard ignition rotor fitted or a third party 'aftermarket' one (typically from Factory Pro) which advances the ignition by 4 degrees.
The picture (below) should help you identify which type is fitted to your machine.
NOTE: If you wish to advance your ignition, but do not wish to fit a third party rotor, then you can modify the backplate instead - https://gsx1400owners.org/forum/index.php?topic=144.0
