JIS vs Philips screwdrivers
Started by VladTepes, Thursday, 30 April 2020, 04:22 PM
T250
Quote from: gsxbarmy on Friday, 01 May  2020, 08:26 PM
Carry on jesting you lot, needing all these special tools for your pimped up rice rockets - all us rockers need is a good hammer and screwdriver to fix our proper motorcycles  :rofl2:
And if that doesn't fix it, it must be an electrical fault!  :happy1:
All good Barmy. Maybe were jealous. Good old Triumph days i remember.Bonnies, Tigers we could fix, Tridents a different story. Still were better than Norton Commando. A fix a day.
Well this thread has drifted a bit.
Barmy started the drift with trumpets . . .  :happy1:
Quote from: KiwiCol on Tuesday, 05 May  2020, 10:47 AM
Yes sorry - need to give myself a  :rulez: :redcard:
SA14
Was watching a FortNine video about "Special Tool Every Motorcyclist Should Own" and what should pop up 3/4 ways through the video but JIS Screw drivers. Thought I'd pop this here. I linked the video at the point at which he mentions Japanese Industrial Standard (which was discontinued in 2008 just like us!) but the whole video's not too bad to watch. For example I didn't know what a Pin Wrench was.
JIS part is at 8:27
SA14
#23
Quote from: grog on Monday, 16 November  2020, 07:37 PM
Mate, JIS work well. Impact driver and maybe a couple of others, youre set. https://rhinotools.com.au/product/vessel-jis-impact-screwdriver/
Added the impact and a few sets of JIS drivers to the cart for later.
In the video at the 9:40 mark he shows how some of the Vessel drivers are actually an impact driver too.
Quote from: SA14 on Monday, 16 November  2020, 07:44 PM
Yep, the JIS set i bought has two impact drivers, the silver handled ones.  Best set of 'drivers ive got, just love them.  I'm restoring a 2004 corolla sportivo for my kids to learn to drive in, use these JIS screwdrivers all the time.  Also on the 1402 of course...
JIS has been discontinued? So I can look forward to more stripping philips heads in future then.
SA14
Quote from: VladTepes on Tuesday, 17 November  2020, 01:20 PM
Unless you modify your phillips head to become a JIS. Apparently the included angle needs to be around 57 degrees and you grind the tip off so it seats fully all the way down into the screw.
Got that info from this thread https://goldwingdocs.com/forum/viewtopic.php?t=15547
Some of the pics (nicked) from that thread below.
Excellent, I'd never found anything specifying the differences.
JIS work way better, even in Phillips screws. Just something to have. A bit like using multi point sockets to single hex, why would you. A lot of cars i work on now use Torx screws, just crappest, easiest to to strip shit ever. Theres even a variation on them, Jeep, Mercedes use, even worse. They dont undo, just break the tool youre using, nightmare stuff.
I ended up buying a Torx socket and key set because of a car I own, realised it when I went to change the oil. There is also Torx Plus for higher torque.
