Adjust your TPS
Started by gsxbarmy, Monday, 06 February 2017, 12:30 AM
Persizi
#105
Is there a problem that the STP sensor looks like this?
Will14
Quote from: Persizi on Monday, 20 November  2023, 04:11 AMIs there a problem that the STP sensor looks like this?
One of mine looked a lot like this, it happened after I had sprayed some chemical cleaner on the bike so assume it was a reaction with the plastic, it didn't change how the bike ran or the setting of the sensor
Same here, a razor blade gets rid of this if you scrape carefully.  As long as the sensor is working fine no issues.
Clean them up, theyll come back the same. Just leave alone.
Bit of black spray paint?  or bit of marker pen . . .
