What air filter?
Started by mikesaa309, Saturday, 07 April 2018, 11:33 AM
Quote from: Speedy1959 on Tuesday, 17 September  2019, 04:59 PM
Whats 3/4 throttle ?
What are all those numbers that go higher than 4 on the right hand clock ?
:imrgreen:
What ya do Si, is get it into 3rd like normal, then when you're about to change into 4th, instead of throttle off & go up a gear, just crack the throttle right open  :devil: (and hang on)  :doh: & watch the wee right hand needle go to where it likes it :imrgreen: - 6's & 7's are it's favourite numbers . . .
:cruisin:
Cykik
So used to driving a diesel car all day I rarely go over 4k rpm on 14...
Started out with nothing, still got most of it left.
Over a year now since K&N fitted. Bike runs perfectly, as it did wit OEM. The smaller intake one i had from Klauss in Poland was ok, I dont go for power but can definately notice perfect revs from start to finish. Also better fuel mileage, never measured but notice a few more ks between fills. Im a big fan of dry paper, so OEM is perfect. Just having to wash out K&N also suits me. Thats a big change for me, always liked dry paper. Things can change.
:imrgreen:
You've got the slower R&B model so it doesn't concern you....
I need to find a seller of a real air filter though, I might even ask the local dealer. Robinson's have superseded their part number to one that includes 'K+N' so I rather suspect it's not OEM.
Quote from: Andre on Wednesday, 18 September  2019, 03:32 AM
Quote from: Hooli on Wednesday, 18 September  2019, 03:27 AM
Attached screenshot is from: https://www.robinsonsfoundry.co.uk/shop/online-store/suzuki-parts-finder/gsx/gsx1400/k2-k3-k4-k5-k6-k7-2002-2007.htm#!gsx1400aircleaner
Yeah but add it to your basket & go to the checkout & you get this.
I've found them online for £24.50.
You can see it's a proper one as the trumpet doesn't extend inside the filter, every aftermarket one I've ever seen does.
https://www.bikersworldstore.co.uk/suzuki-genuine-part-air-filter-gsx1400-k2-k7-13780-42f01-000-ss-13780-42f00-000.html
Certainly looks OEM including the numbers. Good price. I pay 30 € for mine.
Quote from: Hooli on Wednesday, 18 September  2019, 04:41 AM
Would you measure the opening when you get it Hooli?  (and post here)
Might take to my aftermarket one with a dremmel cutoff disc & chop that internal piece out.  The blue has a K&N fitted.
@KiwiCol
Quote from: northern on Tuesday, 28 August  2018, 01:59 AM
Just to compare - K&N inlet is 56mm, versus OEM 48mm and Hiflo 39mm
Quote from: northern on Tuesday, 08 May  2018, 09:00 AM
I replace my Hiflo to Suzuki OEM.
Hiflo intake is 39mm, OEM intake is 48mm - it's area is 34% bigger than hiflo one. Also it's slightly higher - also easy to get air throw.
Local prices are ~25€ for Hiflo and 35€ for oem, so my choice from now on is Suzuki OEM.
Thx Andre, I knew it was on here somewhere, it was a quick visit to the site while at work when I asked the question.
And yet my bike runs just fine with the HiFlo air filter fitted..
Mind you I dont tend to screw my bike everywhere I go so maybe thats the difference.
Quote from: Speedy1959 on Thursday, 19 September  2019, 07:53 AM
With the Hi-Flo, I don't think it affects whether the bike runs fine or not, more that it can restrict performance having the smaller intake.
My bike has always run perfectly with 3 diff types of filter.. Cant remember thoughts/sound on stock paper. When K&N fitted i could notice diff sound even though its a long way from ears.compared to smaller intake/tube down inside type. No testing but also think fuel mileage is better and revs easier above 6k. No test or figures to back up but quite happy with it.
