How to replace the Tea-Bag filter - 3While it's all apart you can remove the pressure relief valve in these pictures and clean the high pressure filter from the other side. (I normally use the large can of carb cleaner).
Note - I've not removed the pressure relief valve as the clips in the plastic are very easily broken .
Also in this picture you'll see the lock wire mod to save the valve coming off it the clips break (details of this mod here
https://gsx1400owners.org/forum/index.php?topic=1610.0)
Once all clean, fitting is the opposite of the removal.
- Do not force anything or you'll break it .
- Remember to tighten but not over tighten the screws and nut .
Hope this helps
