Hi all,
I've read the excellent "Howto" which is downloadable on here..
To sum up it says "Balance 1 to 2 then 3 to 4 using the underneath screws...Finally balance 1+2 to 3+4 using
the adjuster screw between 2 and 3. You only need to move them a tiny amount at a time".
That's brilliant advice and I have been out with a torch and a mirror to view the screws location..
I easily found the outer screws (for 1 to 2 and 3 to 4) but could not locate the screw "located between 2 and 3"..
Is this screw located above? In other words accessed from the top ??
Thanks in advance,
S.
