20 January 2022 - the forum is now 5 years old. Time flies.
Power Commander PC-V Grounding
Started by V_i_c_i, Monday, 13 February 2017, 05:28 PM
Maveric
Quote from: V_i_c_i on Thursday, 23 February  2017, 07:34 AM
So I modify PC V wiring harness and take out TPS wire on the same place as ground.
And connect TPS direct to ECU. Now just fit some 2 PIN connector to PC V and to ECU.  :onya:
Nice  :onya:
I bought a extra connector (male and female) as the one that connect the Tps to the main wiring and solder in the wire there so i easy can remove it from the bike if needed.
Cheers Maveric
Maveric
Maybe i shoud se if i can do a new write up of how to mount a PCV on our bike as the one i did at the old org :).
See if i can this weekend now that i have found all the pic's and maybe take some new one's.
Cheers Maveric
V_i_c_i
Quote from: Maveric on Thursday, 23 February  2017, 08:39 AM
Cheers Maveric
Can send more photos if you want. Including bracket for PC V and Autotune and connecting autotune too. But now I wait for connectors to finish my job.
V_i_c_i
And show us your AFR table would be good topic too.  :grin:
Cheers Maveric
yes please maveric this would be very very useful
seth  :onya:
Maveric
Started to do a complete write up on mounting a PCV on our bikes but i cant find all my pic's how i mounted mine so i will go out next weekend and take some shoots of that plus connect my PCV to the computer to show the afr tables to .
But those that have a PCV mounted can you send me pic's of how you have mounted yours so i can show different types of doing it in the write up, V_I_C_I for example your mounting bracket, lambda position or other things.
You can send them to   magnus.sn.el@gmail.com  and i will put all info and hopefully make it easyer for all to do the same as we have done :) :).
Cheers Maveric
V_i_c_i
Quote from: Maveric on Wednesday, 01 March  2017, 06:37 AM
Cheers Maveric
I will do it over weekend.  :undecided:
V_i_c_i
Maveric
And got the email  :notworthy:.
Start tomorrow to finish the write up as i'm home with a injured shoulder (not the one i smashed when i put the big girl to it's side almost 2 years ago) so i got the time to put it together and i will port it here as a new thread  :).
Cheers Maveric
