GSX1400 Owners .org
A community for owners of the Suzuki GSX1400
Welcome,
Guest
. Please
login
or
register
Have you missed your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length.
Like stats
Home
Forum
Help
Search
Calendar
Gallery
Search
Stats
The Team
Login
Register
GSX1400 Owners .org
Forum
Technically Speaking
Engine & Gearbox
How to:
Replacing the Gear Shift Ball Joint(s)
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic:
How to:
Replacing the Gear Shift Ball Joint(s) (Read 7859 times)
Forum Donor 2022
Needs to get out more
Country:
Total likes: 6224
Gender:
If we werent all crazy, we would go insane.
Re: Replacing the Gear Shift Ball Joint(s)
Reply #15 on:
Wednesday, 10 January 2018, 07:21 pm »
Andre, received my gear lever bushes. 12mm inside perfect on shaft. 14 outside. so now i can remove plastic bush, it will fit also into gear lever? just a bit scared to destroy plastic bush before i know new will fit. thankyou.
Logged
(1 person liked this)
Forum Legend, Forum Donor 2018.
Torque Master
Country:
Total likes: 1700
Gender:
Reply #16 on:
Wednesday, 10 January 2018, 07:41 pm »
There are 2 of the plastic bushes, one from each side. You can lift them plastic bushings out easily with a small screw driver. They come out undamaged unless you do it in very cold temperature as the plastic becomes brittle. Fat chance of that in your neck of the woods
The new ones I got where a little tight after fitting into the gear lever. After carefully (wood piece, small hammer) putting them on the shaft they fit perfect. Your new ones may differ.
Quote from: grog on Wednesday, 10 January 2018, 07:21 pm
...it will fit also into gear lever?
Don't know what you mean by that.
Logged
Forum Donor 2022
Country:
Total likes: 6224
Gender:
Reply #17 on:
Wednesday, 10 January 2018, 07:46 pm »
thank you Andre. my confidence restored. love your work. very helpfull. your input appreciated. i know its only a small thing but would be big to me if it didnt fit. will let know result. all thanks. no def. not cold here. 35 today with big warnings of huge heat for weekend.
Logged
Torque Master
Country:
Total likes: 1700
Gender:
Reply #18 on:
Monday, 14 May 2018, 01:51 am »
@grog
Did it all fit? Does it improve the shifting for you?
Logged
Forum Donor 2022
Country:
Total likes: 6224
Gender:
Reply #19 on:
Monday, 14 May 2018, 05:08 pm »
Andre, fitted new metal bush, spaced with a couple of washers. Plenty of heavy grease. Havent changed rose joints yet, lubed them up pretty well. All working fine.
Logged
Will14
Forum Donor 2022
Tarmac Tearer
Country:
Total likes: 373
Gender:
Reply #20 on:
Monday, 26 October 2020, 07:19 am »
I did the metal bush gear lever upgrade today, all of 15 minutes work and what a difference it had made, no play in the lever now and much more positive gear changes
Thanks for the info
Pete
Logged
Forum Donor 2022
Torque Master
Country:
Total likes: 1591
Gender:
Reply #21 on:
Monday, 26 October 2020, 01:57 pm »
Guys, keen to do the same, what parts do I need? New ball joint ends RH and LH and bushes? Available off ebay?
Logged
Forum Donor 2022
Country:
Total likes: 6224
Gender:
Reply #22 on:
Monday, 26 October 2020, 06:14 pm »
Eric, been a while since gear bushes. I never changed rose joints, just filled with anti dust spray grease. Still good. Ill have a look if i kept spare bushes, cant remember. Very cheap online, cant rem size, maybe 14 od and 12 id, not sure.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
GSX1400 Owners .org
Forum
Engine & Gearbox
How to:
SMF spam
blocked by CleanTalk
anything
