Hello!
My first post here. Just adding a little something.
My pump started acting the other day, turned ignition on, pump wanted to start priming but after a few miliseconds it stopped, having the FI coming on.
Had to turn the ignition on and off a few times till it managed to prime in order to fire up the bike.
Disassembled the fuel pump today 2002 model, following code on the inside of the pump (mitsubishi) UC-T30. Bolt like terminals, positive on the left, negative on the right, a small hole between them and a bit lower while also a bigger hole at the top center.
Codes on the outside were 15100-42F01 (not sure about the number 1 at the end, a bit scratched) and below that, UC-T30SU5.
Called a friend, found the exact same pump that is used by Suzuki Vitara car.
Hope this might somehow help someone someday
