Author Topic: GSX 1400 Ignition  (Read 371 times)
Offline Buck
GSX 1400 Ignition
« on: Monday, 24 October 2022, 02:36 am »
Hi guys I recently bought 2008 FE just the frame engine & loom & ecu for a chop but I didn't get the ignition or key with it is there a way I can bypass the ignition switch as I have just found out there is an immobilizer & resistor  built into ignition that send power to the EFI system
Any help will be much appreciated thanks 🤘
Offline Tony Nitrous
Re: GSX 1400 Ignition
« Reply #1 on: Monday, 24 October 2022, 06:46 am »
On other Suzuki’s it’s possible to deactivate it in the ECU, the 14’s ECU / Flash is a bit basic in its options though so I’m not sure if this is possible ?
anything
