Quote from: horse on Saturday, 13 July  2019, 05:48 PM
Gave the old girl a tub and blow dry another boring black one but at least it's clean now, the metrovac and a foam bath makes an easy job of it, got take the footpeg risers off tomorrow ,
Horse
you need to give it another wash its still black ! :)
Gave Sophie a service (as it were)..
Then for amusement i removed all the stainless header bolts and put plenty of Nickeleaze anti seize on them..
I suppose i may as well go on a ride out now....
:grin:
Bob
I bought Shakys GSX last week, spent a few night cleaning what I could, swapping somethings over and more cleaning, it's been raining everyday here so no test ride until today, fuckin hell  :thumbs_down: quickly back to the house to check tyre pressures, only 20psi front and rear blew them up 36&42, silky handling restored, no sure why I didn't check before I went out as Shaky did say he hadn't used it for a bit, so no blame on him. Even the Campbell's sound ok but not really to my liking, downpipes are horribly rusted although they might be blast able and coated  :onya:
ouch
Got rid of the horrible aftermarket indicators and fitted standard ones and also fitted a quick shifter and new rear shocks
DTTW
I know the "14" isnt a 2005 GSXR750, but a friend with the GSXR (which he's owned from new) ruined his gearbox with an after market quick shifter..
He ended up replacing the gearbox... (£700)
Older bikes were never designed for quick shifters in my opinion..
Plus, is it so hard to change gear normally?
Quote from: Speedy1959 on Sunday, 14 July  2019, 03:35 PM
Not hard.
Not going to be a game changer on an old GSX.
A thing of great joy when factory fitted on a high performance modern bike and used in conjunction with launch control, anti wheelie settings, shift lights etc.
Down shifts with a an auto throttle blipped are nice.
I enjoy changing gears. Only used one quick shift, couldnt get used to it. Not saying good or bad but i like old skool for me. 14 has a great gear change IMO, The old 2 stroke Suzukis had better gear change but probably because of gear oil in separate gear box.
Hi Tony
Another mate has a BMW S1000RR with the factory quick shifter and yes its very good.
It auto blips etc..
But that gearbox was designed from the ground up for a quick shifter..
My mates GSXR750 is rather gorgeous to look at.. A limited edition model.
I can't see a quick shifter damaging a gearbox unless it's setup wrong. They only do the same as a rider does after all -
cut the power
change gear
put the power back on
It just does it quicker. So if it's not adjusted right to have the correct delay between cutting the power & shifting, moving the shifter the correct amount etc etc then stuff will get damaged.
Will14
I have managed to get a good few hours in the shed today & managed to get plenty of tinkering done:
New EBC Double H pads to the front & rear
Refitted the wheels now that I have had the new tyres fitted and adjusted chain etc
Cured a couple of small leaks on the collector box from where the previous owner didn't to a great job fitting a new collector
Checks and adjusted TPS & STPS - Cold start wasnt working previously, it is now  :)
Checked the external fuel filter while I had the tank up & no signs of any contamination
Gave a quick clean & polish, even if I do say so myself she looks pretty fine for 18 years old
Agreed Will14, she looks fine indeed, :smitten:  now the question is, can you keep up with the 18 year old?  :whistling:
Has she got the wrong rear shocks? red springs are K5 onwards aren't they? Not that it'll make any difference to how she rides etc.
Will14
Quote from: Hooli on Monday, 15 July  2019, 04:35 AM
Yes, she had the silver springs shocks fitted last year when I purchased it but as usual they were seized, even worse someone had been into the adjusters. I made up some spacers so that they would permanatly be set at three rings then I came across this pair of Red Spring shocks & swapped them around
Cheers
Pete
